Mazdarotaryclub.com
undefined
Click to visit our Online Shopping facility
Click to Join the mazdarotaryclub.com Online Cick to enter the 'Full Club Members' section of the Forum Click to visit the Club Calendar section of the Forum Click to visit the Club Picture and Video section of the Forum
MRC Advertising Disclaimer: mazdarotaryclub.com does not endorse any of the Advertisers on the site and therefore Mazdarotaryclub.com cannot be held
responsible for any issues between individuals, whether Members or Guests, & Advertisers resulting in loss of money. It is the responsibility of the
individual to assess each Advertiser accordingly.
Go Back   mazdarotaryclub.com > Photo's and information on Members Cars > 3rd generation RX-7's
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 16th July 2009, 11:09 AM
jackaleks jackaleks is offline
MRC Guest
jackaleks is on a distinguished road
Supra fuel pump
asked my local friendly Toyota dealer about a Supra pump and quoted part number 195130-1020 (as per here) but Toyota don't recognise that at all, they came back with this:
part number 23220P
does anyone know if this is the part?
  #2
Old 16th July 2009, 12:24 PM
Aubec Aubec is online now
MRC Guest
Aubec is on a distinguished road
The first number you quote is Denso's part number, not Toyotas. From the diagram that looks right, assuming that IS a diagram for the Twin Turbo and not some other car.
Let us know what they charge you for it.
  #3
Old 16th July 2009, 12:57 PM
MRC Guest
£165 + VAT at the dealer. there's a second hand one on eBay at the moment but i don't see the point in replacing a 15 year old Mazda one with a (probably) 15 year old Toyota one!
thanks for the replies, i think i'll just order one and see how it goes.
  #4
Old 16th July 2009, 01:27 PM
MRC Guest
You can buy a brand new pump on eBay from the states for much much less than that. Think I paid £105 including shipping a few months back.
  #5
Old 16th July 2009, 01:34 PM
MRC Guest
It WAS item 220361500327 on ebay that I bought - I cant access ebay from work so dont know if its still there or not.
  #6
Old 16th July 2009, 02:22 PM
SmbFD3S's Avatar
SmbFD3S SmbFD3S is offline
MRC Full Club Member
SmbFD3S is on a distinguished road
Also depends whether you want a UK or Japspec one... The UK one's flow more paying £136 for mine
__________________
'92 UK RX7 FD
'97 Kwak ZX6R currently at Stage 3
'86 Honda CRM250R stroker
'06 BMW 120d M Sport
  #7
Old 16th July 2009, 08:22 PM
Grizzly Grizzly is offline
MRC Guest
Grizzly is on a distinguished road
Am i missing some thing here? You are thinking of putting a £165 + vat Supra Pump on an FD? Why not fit an Good after market one that will flow more and be as good for less money?
http://www.mazdarotaryclub.com/forum...ad.php?t=48401
  #8
Old 16th July 2009, 08:25 PM
ashc ashc is offline
ashc is on a distinguished road
and watch out for ebay fakes, there were some crap walbros going around about a year ago anyway.
  #9
Old 16th July 2009, 11:07 PM
SmbFD3S's Avatar
I'm fitting a supra TT pump simply because it's a direct replacement for the original and requires no modification and will run as the original withouth worrying about keeping the fuel above a certain point or swirl pots. While the 044 maybe a better pump, the Supra pump will still support 450rwhp and i was under the impression the 044 was better as an inline pump and if you did want it intank then you'd have to mess about with it to get over the starvation as said in that thread....
__________________
'92 UK RX7 FD
  #10
Old 16th July 2009, 11:28 PM
MRC Guest
Quote:
hit the nail on the head
i'll shop around for a price but the main reason is that it flows more than OE Mazda, replaces my crappy 15 year old one and requires no buggering about to fit.
  #11
Old 16th July 2009, 11:35 PM
SmbFD3S's Avatar
I'll do some shopping around mate and see what the best price is i can get although i've already got a price of £136 for a UK spec one so would be good to know if you can get it any cheaper?? and likewise i'll let you know
__________________
'92 UK RX7 FD
  #12
Old 17th July 2009, 02:05 AM
MRC Guest
450rwhp? that's allot on an FD you sure it's that big if its the same size as stock? don't forget that because it flows enough for 450 on a supra don't mean it will do the same on a FD, if its a direct replacement its going to be allot smaller then a 044 (btw the 1/4 of a tank thing is fixed by fitting the sock filter) and the funny thing is its harder to remove the stock Pump without damaging the sender etc than it is to cut the feed pipe down to fit the bigger pump (044 can be run intank).
When you say replace the 15 year old pump don't forget to replace the 15 year old wiring as that's the main cause of low voltage/Poor fuel supply.
Stock v's Bosch 044
  #13
Old 17th July 2009, 08:19 AM
SmbFD3S's Avatar
From rx7store.com
"The stock fuel pump was designed to handle the fuel requirements at near stock levels. Once you've upgraded the car to a point where more fuel is required, you'll need to address this weak link in the system. We use a special, high flow fuel pump, made by OE manufacturer NipponDenso in Japan, which exactly replaces the stock fuel pump. This unit takes less than 30 minutes to install, doesn't make any more noise, is extremely reliable, requires no cutting, welding, new lines, or anything else. It's also the highest flowing unit we've tested that doesn't make the car run rich at idle, unlike other "bolt ins".
The pump has been tested to support 450 RWHP (at 36-40 PSI base pressure) and is a good upgrade for those with upgraded ECUs and/or those adding additional injectors. "
On the note about the wiring, yeah i will also be doing that and using this pic/guide from rx7club:-
__________________
'92 UK RX7 FD
  #14
Old 17th July 2009, 08:36 AM
MRC Guest
i was going to sort the pump and fuel filter so that when i (finally!) get hold of a Power FC there will be no possible issues when mapping. i'm not really going for huge huge power, just a quick reliable car.
good shout on the wiring, as my battery is in the boot now it'd probably make sense to re-do it.
  #15
Old 17th July 2009, 12:05 PM
MRC Guest
From rx7store.com
Funnily enough i know the Turbo2 that did that run.
http://videos.streetfire.net/video/R...k-1_693497.htm
Stock internals brand new S5 motor
Supra TT pump
T04Z turbo with 1.15 AR
3.5 inch Exhaust
Aeromotive FPR
parallel AN fuel system W/ KG rails
850cc prim 1600cc sec
Greddy FMIC
Custom 4 inch cold air intake
Microtech LT10s
Coolingmist trunkmount kit
ECT ECT
"Thanks for the comments everyone! ill answer some questions now...first off yes the meth made a big difference, intake manifold felt like ice after a dyno pull..this motor is bone stock internals, no porting at all, i was running 93 pump gas and 50/50 meth water, and i think my injector duty was 40% at 15psi and 65% at 18psi...im not 100% sure though. i knew i had plenty of fuel so i wasn't to concerned with keeping track of the duty cycle. Here is one of the dyno sheets.. "
Not bad for a car with smaller ports then an FD.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Denso Toyota Supra Fuel Pump Timmy Anything Engine/Performance/Tuning related 9 19th April 2008 12:56 AM
Help with R33 Fuel Pump or Supra one gmogle General Technical 7 22nd August 2007 04:54 PM
Walbro supra TT fuel pump Fats Anything Engine/Performance/Tuning related 5 27th May 2006 11:44 PM
Is it a fuel, or fuel pump problem? MintyFresh Anything Engine/Performance/Tuning related 2 1st June 2004 12:25 PM
Powered by vBulletin® Version 3.6.9
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
